Paul O'Donnell mentioned in another thread that he was planning to install a UL Power 520 - something that got me thinking a lot more about it, so I did a spreadsheet (of course I did !) comparing several of the more common engine installations. It's by no means definitive, and uses my best weight estimates based on already known actual aircraft weights, published engine weights, and published HP/density altitude charts. I've added a column to illustrate Power/Weight ratio (actually Weight/Power but you get the idea). The lower that number, the better the expected performance.
I've compared the UL520T (Turbo) to these engines because I was really interested to see the effect of a modern engine, turbo normalised (maintains sea level manifold pressure to 15,000ft), single level engine control. The one main issue would be CG.
The UL520T is approximately 180 LBS lighter than a typical IO540, so if the CG issue is resolved it will provide very similar Power/Weight at low altitude, and once above about 3000ft density altitude it starts to exceed that performance in every way. I didn't calculate cruise speeds, but with a surplus HP and better Power/Weight at all altitudes above 3000 ft, the cruise speeds (both IAS and TAS) should be significantly better. Landing performance improves due to the lower total aircraft weights when compared for the same payload due to a lower approach speed (and hence less of those pesky V² 's) and shorter landing roll.
The chart below compares various engine installations at a Take-off Weight (TOW) of empty weight + 640 LBS.
..but the results look like its going to be a very impressive climber that's going to use a lot less fuel. In Ireland Avgas is 2.70 euro a litre vs Mogas at 1.70
. The UL is happy to sip either one of those. It will be very interesting to see what the cruise speed will be.
