Starting to really enjoy welding the fuselage. I highly recommend the XL tig finger. I had ordered the smaller tig finger as well, but have not ended up using it for the fuselage. The XL slides nicely past your four fingers and works well to rest against the hot tubing.
Yesterday I tried out this large gas lens set from weldcity. The #10 tapers down to a workable size, and you can get very long electrode extension if needed. I've had it out further than shown in the image. The big lens and tapered cup seem to funnel a nice stream of gas. I also really like the ergonomics of gripping the cup. This lens and torch combination seem to work well for this application. It really pushed the gas into the odd shapes, angles, and corners encountered on welding the fuselage.
I've found that feeding the puddle from the rear works well on the tight elbow joints.
