Very interesting, I'm glad you've brought this up. As far as I know, Matco does not make a weld on 1-1/4 axle. I've been planning on using a set of pre threaded and ground axles from Aircraft Spruce: http://www.aircraftspruce.com/catalo...p?recfer=23685 These have 12tpi threads, I believe Cub 1-1/4 axles do as well. Looking closer, the LSA plans call for 16 threads per inch. The bolt on Matco A3A uses the 16tpi as well. I'm assuming the finer threads would help in attaining proper bearing preload and pinning the axle nut.
Did you cut your axles from tubing, or purchase a pre made set?
Did this SB you were referring to that detailed this spacer come with your wheel and brake kit? I sent the drawing to George at Matco looking for guidance on which products to order for my application last week. He didn't mention anything about the spacer you have shown in the photos above. I was assuming that the bearing rest against the 1-1/2" axle sleeve shoulder, and the seal came around the 1-1/2" axle sleeve.
I'm sure I'll get some ribbing for flying around something other than a cub with 35" bushwheels.
