I have obtained some additional information since my last post that takes a bit of air from under my wings and leaves me a little less excited about the path that I was planning to take in forming the ribs.
It turns out that the dimensional discrepancies in Dwg 4 are not printing or drafting errors but rather an intentional modification to the wing profile. I have learned that the modification, in some form, also exist on the mylar of the Patrol, 4-Place and possibly the Model 5, as they share the same profile and chord dimension. I don’t have the mylar for any of those aircraft so I can’t verify what I learned from other sources. I have calculated and plotted the GA30-413.5 airfoil with a 65.125 inch chord should anyone want to do the comparison. Link below. So, the answer to the obvious question seems to be completely unknown to anyone except Bob, and he appears to be deflecting or obfuscating, based upon my research and the answer obtained recently by Mark, on my behalf.
If the modification was done to improve performance or flight characteristics, then why did previous members not receive that information as an answer to their questions years ago? I’ve also learned that some aircraft designers, including Steve Wittman, would sometimes attempt to smooth-out the concave portion of a high camber wing in order to make rib forming a bit easier. If that was Bob’s reason for the modification then why not tell us? I can also speculate on a couple more possibilities but sometimes speculations can be interpreted as accusations and I certainly don’t mean to infer anything negative.
If the modification was made in order to make rib forming easier for plans builders, then what about the factory ribs? They were formed in the -O condition, thus much easier to form, so do they have the correct 613.5/413.5 profile or are the ribs formed to their respective mylar profile? The LSA is marketed as having the Riblett GA30-613.5 rib but that is only partially correct as it only applies to the plans set drawings. If the factory ribs are formed to the Dwg 4 dimensions, that marketing statement would not be correct as the Dwg 4 ordinates are not obtainable by calculations using Harry’s GA30-015 basic thickness form data with the GA-6 camber data. It might, then, be more correct to refer to the wing rib profile as a Bob Barrows modified version of the GA30-613.5 instead.
Having purchased our chosen aircraft plans set, does that cost not include the information that we might want or need that would further our knowledge and understanding of that aircraft and, specifically, what modifications were made to the airfoil that technically changed it from a true 613.5?
I might be the only current forum member that would like an answer to these questions but, based upon my research, there have been many more over the years. There are, likely, only a handful of people on this forum that could ask these questions to Bob with the persistency possibly needed to get an answer without creating animosity. And none of those are me…
Best regards to all,
Mitch
P.S. Until a few days ago, I was assuming that I would be forming my ribs to the true 613.5 profile. Maybe still. Although I planned to have the master template CNC cut, I still wanted to have a mylar drawing to use as a reference at times and to maybe hang up on the shop wall. Duncan-Parnell was my source for topographical maps back in the late 70’s and I knew that they were still in business and now had a location in Concord. Still a 45 minute drive but a nicer drive than to Charlotte. They only had 24” mylar so I put two different profiles onto one 65” length. It was $19.00 plus tax. Not too bad, I don’t think. I have included a link to the PDF that I had printed should anyone like to have it for any reason. It might make a good conversation piece for your workshop. It cost about $6.00 on standard paper.
Riblett GA30-413.5 Airfoil Profile - http://rf-tech.us/lsa/Riblett_GA30-4...art_Points.pdf
Table of Chord Stations and Ordinates for the 413.5 Airfoil - http://rf-tech.us/lsa/Riblett_GA30-4..._Ordinates.txt
Riblett GA30-613.5 Airfoil Profile and Chord Station Dimensions - http://rf-tech.us/lsa/Riblett_GA30-6...l_Profiles.pdf
Mitch
Have you ever cooked a big cast iron pot of chili beans over an open fire? You got to keep stirring or those suckers will stick to the bottom and create a big mess!! I promise you, it is not my intention to stir the airfoil pot and, more seriously, not to offend anyone. You may remember from my original post, I learned about the Dwg 4 issue, or whatever we may call it, about 4 years ago and I can not find any resolution that is documented. I'm pretty darn sure that there is a reason behind it but I can't find an answer. I don't mind calling Bob but based on his response to the question over the years, I'm relatively certain that he wouldn't be forthcoming. I did send an email 2-3 weeks ago, no response, but I will not rule out that phone call, eventually. Maybe even a physical visit. He isn't' too many hours away and seems like a nice guy to chew-the-fat with.
