Shimming the aileron mounts is a very effective way to trim for a heavy wing. A left turning tendency can be cured by adding
washers under the TOP aileron hinge mounts on the left wing spar. This in effect "lowers" the aileron in relation to the wing, causing it to produce slightly more lift. A high aileron equals a "heavy" wing. If this doesn't completely correct the situation, you can additionally add washers under the BOTTOM of the right wing.
Collin
Collin
