Hanging Carlo's Wings on His Patrol
  • Hanging Carlo's Wings on His Patrol
    Spent a toasty Sunday at Frederick Airport getting Carlo's wings on. Clock is ticking on this one, as the owner of the hanger next to Carlo's (very full hanger) is out for a few more weeks (Cirrus jet touring Europe). Usual conversations on this stuff as shown in the video screen grabs. Once struts are on, final welding on the fuse, final prime and paint, and the engine gets hung/firewall forward stuff. Sept 2023 purchase of plans for Carlo, so a pretty decent speed-of-build. Should mention Carlo spent the winter getting the panel and all the wiring harness, windows, and cockpit interior build out, so further along that it might seem.
    We used a couple laser levels (the Takamine four line is shown on tripod - good option of you don't want to sink over $500 on a Bosch three line) plus some calibrated digital levels for incidence, fuse leveling, etc. The platforms are pretty rudimentary, but using an almost empty hanger has its benefits, as once set, unlikely to be disturbed.
    I found digital levels to be surprisingly inaccurate and not repeatable. Ultimately the water level was the most accurate. laser is an interesting option.
      I had several water levels going on the day I hung my wings
      1) fuselage
      2) root to tip on each wing, so 2
      3) wingtip to wingtip Yep it was about 45’ long
      Worked like a charm
        The lasers were surprisingly accurate for mass-produced tools - the biggest issue was line width and brightness at longer distances. Closing the hanger door addressed the brightness issue, and the 1/16" apparent line width just required consistency in use. I did cal on my shorter (24") digital level using a larger leveled surface plate in the lab, and shims showed a consistent flip to the next tenth. At angles around 45 degrees from horizontal and vertical, we saw closer to .2 variation when flipped, but that could have been my plywood and rare earth magnet rig! Carlo got things closer the next day and did a final check with water level before doing the intermediate ream to AN3.
        One thing to consider is that 1/10th of a degree is about 0.3" vertical change on a 15' span between mount and the outward vertical measurement point - a water level should get you to at least 0.1 inch accuracy, so another good reason to use a water level as a final check/tweak.
        What really surprised me was just how square and true the fuse was off the jig, as well as how straight the wings were. What became apparent as the fuse was leveled was that time and care in building out a rock-solid jig def paid off, to include the uniformity in timber size (trued on jointer two-adjacent-edges, then sawn to width and final-sanded to consistent dimension), a modular leveler design, and seasoning the wood a bit to get it to ambient for Maryland in Oct-Nov.​
          See post #7. I read a water level to 1/2 mm (0.5mm = .020") with 3x reading glasses when I drilled my wings.
          I am setting things up to drill my wings and I have a question specific to where the spar plates attach to the fuselage attach fittings....if things work out I will
          One other consideration. Where on the wing's span should the level reference be measured at? Wing root? Wing tip? I never asked that question when I drilled my wings. But I think it was Paul Johnson who suggested to set the wing incidence by referencing an outboard area like in the middle of the aileron area rather than the root like I did. There is more leverage out there to induce a roll force, so if things are off a little bit then focus on getting the aileron area set right.
            We used the aileron and flap rigging templates for setting incidence - rigged just outboard of the inboard aileron hinge. But should not be an issue, given how dead flat all our wing panels are (in our dreams)
              digital levels suck----- not very accurate..... disappointing performance.....
                Carlo's wings are in paint after getting plumbed... and we have the wet wing versus separate tank total and usable fuel numbers: Carlo's wet wings are 32 gallons total and 31 gallons usable, versus a nominal 28.5 versus 27-27.5 usable for stock tankage... so about 3.5 to 4 gallons additional fuel per side re: range, duration.
                Re: reduction in wing weight... there is weight savings despite the additional sheet thickness on the underside of the fuel bays (.040) and a change to overlap and rivet schedule for the inertial loads and revised venting scheme, but I don't have a hard measurement from actual weighing of the wing in the green, as there have been other revisions such as elimination of the stacked inboard ribs in favor of a stretch-formed inboard flange and bulb-section stiffeners, revised flap scheme (elimination of cables in favor of overhead push-rod Super Cub like scheme), etc. My guess is something close to 8-10 lbs total (4-5 lbs per side) elimination of straps, hardware, and weight of the tank itself, but then there is the added weight of sealant, upgraded thickness of the bottom skin... probably between 6-8 lbs net weight reduction with wet tanks, which lines up with some of the data in my collection of design and structures refs.
                Is it more work than the standard tankage? I think so - especially for someone that has not done other wet-wing work in terms of construction. Sealing is something that is just pretty darned picky work, but generally does not get done again for a good long time.
