I am setting things up to drill my wings and I have a question specific to where the spar plates attach to the fuselage attach fittings....if things work out I will be drilling them in the next day or so.
I have the drill guides from Mark G., and inserts fabricated from .028 tubing that will allow the holes size to step up 1/16th of inch at a time. I thought a mounting a chuck on the end of a rod would work for a drill extension, but my chuck is too large and will conflict with the fuselage tubing. I need a chuck smaller than 1" in diameter. might not make them....??? I am about to check Menards for a drill extension....I think I will need to use the drills with a hex end on them. Is that what other are using? (I dont have enough tubing on hand to fabricate extended drill bits by inserting/spot welding the drill bits into long pieces of tubing like the build manual discusses.)
The build manual talks about leaving the final holes undersize by 1/64th then ream them up to final size? I like that idea. But I dont have a guide for the undersized drill bit. In other words, I have a drill guide for the 5/16" drill and the 3/8 drill bit to drill the final holes for the front and rear spar holes, but if I wanted to drill them undersize 1/64th of an inch then ream them to size how is that going to workout if my insert is not set up for that smaller drill?
Brooks
Brooks
