There is one part of the Patrol that is not too well documented in the plans. It is the inboard side of the flap where it abuts the fuselage. You need one extra flap rib (each side) to make this most inboard part, and a piece of .032 AL which wraps the flap rib and connects (with rivets) to the main part of the flap. You see in the picture how the shape of the .032 turns out more or less. Like in many places, I used cardboard/poster board to simulate the part before cutting any aluminum. What you do is lower the flaps the full 40 degrees. Then you want to set this part up so you have 3/16" to 1/4" of clearance from the rear window acrylic. FYI - Bob says 1/8", but that seemed a little close to me.
I have seen this area dealt with in different ways in the finished Patrols since the detail on the plans is lacking. But this is what Bob had in mind. Can take some more pics if my description is not clear. Mark
