To anyone using a Dynon system - where did you locate your remote compass?
Dynon remote compass
My garmin is in the right wing tip. Before closing I made provisions to run the wiring behind the rear spar. My radio shop wanted the wires uncut between the instrument and the magnetometer. It was a pain to run the wiring after the wing is closed and installed on the plane but it can be done. This keeps your landing, nav and strobe wiring away from your compass wiring. I did the same on the left with the Dynon wiring.
I made a join at the left wing root and used shielded DP connectors. I should be OK as far as the Dynon tech's say. Mounted on a small shelf between the last two ribs at the tip. I am also running the two OAT prob wires through the same shielded cable bundle with the blessings of Dynon too.
I'm thinking the "Dynon Compass" is not the same as the ADHRS? But the ADHRS is also the compass. We placed ours on a leveled shelf behind the baggage compartment. Easily reached and the frame has not interfered with it's operation. When it comes time to swing it, it's pretty cool. We did the compass rose thing and the darn compass would move around and be correct in only one direction of flight. Tech support told us to go out and fly a slow, gentle 360 degree circle in both directions--WaaLaa, perfect! Some one told me that's how you swing the compass in an I Phone. Just hold it out and move it around in a circle 8 or something. Neat. ;-)
Yea,I’m remembering that now. They came out with it right after we bought our Dynon package. I suppose if you could not make it work through the ADHRS location, that would be a solution. A regular compass is on the list of necessary daytime equipment but is it necessary with the Dynon remote?
I heard about others having trouble and used the remote sensor from the start. My attitude sensors are in the wing root between the fuel tank and the fuselage, which is only a foot or so from the magnets that hold the windows open! Similarly, my skylight cover is held in place with magnets. It is convenient to not have to worry about magnetic fields in the cabin or cockpit area.
