Well, sort of. My Patrol is a delightful plane to fly. Good short field performance, nice speed, excellent control authority and very predictable behavior. I never saw the speed I'd heard of, but just attributed that to her being a bit heavy and maybe not as clean as some. Until today.
Some background: 9BK sports a Bob built O-360 swinging a MT constant speed prop. On the panel is a Garmin G3X. From the beginning, 2550/25" was good for 140 MPH. Very respectable for a STOL aircraft, but not the 150 I'd heard of. Something that nagged at me, was the G3X wind indication. It's a great feature in that you always know what the winds are, where you're flying. Really nice feature for choosing cruise altitude. Problem was that I saw an awful lot of tailwinds, when I didn't expect them. With a limp windsock, I'd fly final with 6 or 7 MPH tailwind.. I figured that I had a static system problem, thinking that the side mounted ports were seeing higher than desired pressure. I stuck some tape blocks ahead of the ports and this helped a tiny bit. Still, I was perpetually blessed with tailwinds... Yeah right..... Mentioning this phenomenon, during lunch with a few other builder/pilot/smarter-than-me types, one fellow mentioned that I could have a pitot leak. Well, a light went off! I knew there was an issue and had absolutely convinced myself it was a static system flaw. Thinking about it, a pitot leak made sense!
Long ago, I read an article about using surgical tubing to test pitot static instruments. Slip some surgical tubing over the pitot and start rolling up the other end. It slowly builds slight pressure, allowing you to pressurize the pitot system without damaging the instruments. Mine was leaking so badly, I couldn't roll the tubing fast enough!
I used "Speedfit" tube fittings throughout my pitot/static system. https://www.usplastic.com/catalog/de...arentcatid=606. Great pieces that are easy to use and work well. I found one tube that hadn't been inserted quite far enough and one with some adhesive (presumaby from the tape that held the nylaflow tubing in a coil) in the fitting. After correcting these issues, I could roll up about a foot of the tubing, producing 70 MPH on the display and it held as long as I held the tube roll.
Couldn't fly yesterday, after the fix and thunder bumpers are building today, but I was able to take a quick lap of the area. That same 2550/25" now yields 150 MPH TAS. This is at 1000' MSL. The great thing is that the error was greater at high airspeeds, due to the higher pressures, so I still touch down about 40 MPH. When the weather behaves a bit, I'll go higher and get some speeds at altitude, and a top end run. But I can now say that my Patrol can cruise at an honest 150 MPH! Not bad, huh? 10 MPH more speed and no increased fuel burn!
