1F84F181-18A6-4D12-97CE-E5127C613BC7.jpeg I built a rottisserie out of engine stands. Used in on the wings. I put universal joints on both stands. Worked pretty good, but had some issues with the wing “flopping†due to its weight, until the limit of tension was reached. I now wish to mount the fuselage on the rotisserie. The firewall mount seems pretty well documented by most guys and similar construction used. Harder to see what others did at the tail end though.
There are 3/16 holes for the flying wires on the rudder-mount post, top and bottom. Could I suspend the fuse from tabs bolted through those holes? Would that risk bending the post when the fuselage is sideways? The other obvious mounting spot is the stabilizer carry-through tube. It’s strong enough, but doesn’t lend much support near the top of the fin either. Stinger tube doesn’t help top end at all.
Looking for suggestions. Picture shows what I’ve been using for wings. I don’t weld, so I depend on friends and cash at welding shops so it needs to be simple.
