I have been working on the boot cowl, tunnel and belly pan on the patrol. Everything is going pretty well but I am struggling on how to make the transition between the belly pan (the piece behind the tunnel) and the lower rear portion of the boot cowl between the gear legs. Should I leave it open between the two sheets and just have the tube exposed and add a fairing later, create a bend in the boot cowl or belly pan and add nut plates to join the two together, or something else? The area I am talking about is the area highlighted in the photo below.
