After 6 months and about 50 hours of flying, I think I'm getting the hang of this airplane. I've got a kit built 4-place that I purchased from a builder here in Brazil. It has a Continental IO-360 spinning a variable pitch Hartzell. Since July, I have been "fixing" a few things. New tailwheel, oil pressure gauge wasn't working (I like to have that when I'm flying), Static pressure was vented into the cabin, new VSI, new fuel selector valve, cleaned the dirty fuel out of the tanks, etc.
My airspeed rarely shows over 120 mph. It seems fine below 100 mph, but at higher speeds I don't trust it. I did some "testing" this week. Very generic, but I'm not seeing the airspeeds that everyone else seems to be getting so I did some flying using GPS groundspeed. I set my throttle and prop at my desired setting and then flew one direction until speed (vertical and horizontal) was stabilized and then noted GS over a period of time. Turned 180 degrees and did the same thing. Here are my results; ground speed MPH at 1500 feet....
2300 RPM at 23MP: 106 mph
2400 RPM at 24MP; 115 mph
2500 RPM at 25MP; 125 mph
I did one long range flight where I was able to measure fuel burn accurately. At 24 squared I burned 38 Litters / hour (10 gallon). Do these seem to be in-line with those that have a 200 hp 4-place?
Matt
A couple landings: https://vimeo.com/182907800
Matt
