Aileron Servo placement
  • Aileron Servo placement
    Right wing is a good place to locate aileron autopilot servo, so I would like to see any pics of their installation. I have a convenient spot in mind, but a clean attachment to the bellcrank is eluding me. Would be nice to use the same hole in the arm as the pushrod, but there is a clearance issue with the support tube.
    N57PM Glasair Sportsman
    This is how i mounted my A/P servo in the RH wing
    • U2fletch
      U2fletch commented
      Brilliant! I initially dismissed the capstan idea because I thought I needed to get to both cables. Nope, it’s a closed loop you just need to grab one.
    I mounted mine under the copilot seat. It is a very accessible place and a good place to tie into the Skyveiw network.
    Roger
    QB Companion C-9
    N51RK
      I know Virgil is working on a adapter plate to mount the servos. Not sure the status as I am not to that point.
      Travis
      Travis M
      Kentucky
      Received December 2022
        Here are some pics that Virgil sent me.. Servo2_resized.jpg Servo4_resized.jpg Servo3_resized.jpg Servo1_resized.jpg
        • 500AGL
          500AGL commented
          This is the pitch and yaw servo locations, at the last fuselage station. Pitch is a pushrod to the elevator bellcrank and Yaw is bridle cables to each rudder cable.
        • Dpearson
          Dpearson commented
          Thanks for sharing the photos! I'm planning to follow this general approach on my BH4 build. A couple of questions:
          1. Do you know material thickness and spec for the mounting plate? 2024-T3 or ???
          2. I was planning on a capstan + pulley approach for connecting the yaw servo to the rudder cables, using one bridle cable with a ball in the center and bridle clamps (Vans CS-00022) to connect the bridle cable to the rudder cables. What I see here is one long arm, which I imagine is long enough to line up the bridle cables at each end with the rudder cables as they exit the fairleads. I think this is quite elegant, but I'm wondering if the GSA28 servo will have enough torque to overcome the air loads on the rudder in my application. The RV-10/14 installation is similar, with a total arm length of about 4.75" according to https://vansairforce.net/threads/van...0/post-1258276 . In my BH4, the arm would be 9" long to line up with the rudder cables. The max torque spec of the GSA28 Servo is 60 in-lb (from the G3X Install manual), yielding 60/4.5=13.3 lb maximum "pull" on whatever rudder cable needs pulling. The rudder pedals give a ~2:1 advantage, so 13.3 lb of cable force is equivalent to 6.7 lb of pedal force. Does anyone know if this is sufficient for actual control surface loads the autopilot will encounter in flight?
        Here is a pic of my final installation of the aileron servo. 20250705_122130_resized.jpg 20250705_121944_resized.jpg
        I used .062" plate that I had sitting around. Probably 6061. With the flanges and riveting to the ribs, it is very strong.
          Here are pics of the rudder and elevator servo setup using the capstan. I machined my own blocks for the cable attachment.
            Are there any updates on the official bearhawk servo install?
            U2fletch Any chance you will publish drawings or more details on your brackets?
