I recall that this was somewhat of a debate, but in starting the boot cowl on my quickbuild kit, I see the potential to use rivets for a permanent fastener, or nutplates to allow disassembly.
I tend toward flexible solutions, so even though the nutplates are more work, should I use them for EVERY fastener in the boot cowl? Do any of the joints just work better as rivets alone?
I'm sort of paralyzed by planning and understanding of this phase and I'm terribly afraid to drill any unnecessary holes in my nice firewall flange.I also HATE drilling out rivets.
I imagine that most of these parts will be painted on my bird and that will necessitate removal of the panel for the painting process. I really don't like spraying assemblies as paint gums up screws and coverage is almost always not as good.
Current progress:
Stainless tunnel clamped in place. I'm ready to poke some holes in the bottom flange of the firewall, but unsure if I should use rivets alone or nutplates for that joint. I stuffed a 1/4" thick piece of wood between the firewall flange and the fuselage tubing to block it for drilling.
The tunnel fit mostly perfect out of the box from B.A. I only had to trim the forward flange edge to prevent it overlapping the firewall flange when it's turned upward.
I'm obvious a newbie at this and sheet metal work in general. Any tips or pointers are welcome.
Current progress:
The Pacer uses both counter sunk and flush nut plates to secure the bottom cowl and center top cowl .
