Did anyone here who's completed their instrument panel and glareshield NOT use the angle aluminum supports that tie the instrument panel to the firewall? In Eric Newton's finish manual he shows some 3/4" angle tying the panel to the firewall, which seems like a good construction method, but is it necessary if your panel won't be holding a ton of avionics and instruments? I'll have a piece of glass (G3X Touch) and a radio/transponder, and not much more. Is the overlapping glareshield and boot cowl side strip make for a rigid enough combo? Or does the angle just make for a nice stiff attachment point that's easy to add the nutplates to?
I will be use the smaller 1/2" angle on the instrument panel curvature as the shelf for the glareshield. Any pics you guys have are incredible helpful. Thanks. -Z
