I am getting ready to start a scratch build 4 place. I can oxy weld, but I have a propane torch no acetylene. Is the temp going to be too different, or can I use the same tips it recommends in the manual?
Welding the fuse
It's too bad the tinman isn't still a community regular, because he'd be able to answer your question for sure, but at this link he says he doesn't recommend his propane meco tips for steel:
Originally posted by jaredyates View PostIt's too bad the tinman isn't still a community regular, because he'd be able to answer your question for sure, but at this link he says he doesn't recommend his propane meco tips for steel:
https://www.tinmantech.com/products/...cessories/#pro
And to rub it in a bit...this is at the fourth oldest village site in Alaska
Using Kent’s planishing hammer to form fairing for the PA18 gear.Last edited by Mark Moyle; 02-20-2019, 09:22 PM.
- Likes 4
Here's a quick bit on propane vs oxyacetylene from a welding standpoint:
Ever so often, the question of whether one can use Propane instead of Acetylene will pop up. Learn the difference between the two, and how to prevent accidents.
You might be able to use propane for heating tubes for bending purposes, but not for welding. There's some magic chemistry in there.Christopher Owens
As previously stated, Propane is not used for Oxy/fuel welding. I’m not an engineer or chemist, but have discussed the subject with both. I’m told that the Acetylene flame liberates more CO2 than the Propane flame. It’s the CO2 that acts to shield the weld from atmospheric contamination. Like I said, I’m not a chemist, but the phenomenon can be demonstrated pretty easily. Cutting light gauge steel sheet with Acetylene isn’t easy, because the cut tends to re-weld itself as the cut proceeds. Cutting with propane, as the fuel, doesn’t weld up the cut. It leaves a nice clean cut, because it just can’t weld up the gap.
Originally posted by Chewie View PostMikeos98 might be asking more about the application of his torch tips, not the fuel. But interesting dialog, I didn't know any of that about propane.Christopher Owens
We had a oxy/propane welding setup on the farm. I never used it but I guess they were sorta popular in the 70s. I’d call or email the Tin Man. I don’t know enough to be able to offer anything meaningful. I’d be concerned that the combustion products of Oxy/propane don’t shield the weld like oxy/acetylene does.Scratch Built 4-place Bearhawk. Continental IO-360, 88" C203 McCauley prop.
Used miller Maxstar. Best (arguably) Tig machine for steel only and not too expensive used. Having the aluminum capacity jacks up price 4 or 5 times. !!!!!!!
I think I remember kent selling different tips for the meeco midjet for non-acetylene gasses. Cant remember if it was mapp or propane.
T
