Hi guys, I'm wrapping up my spars and preparing for wing assembly. I'm curious how others are securing the spar tip / tip rib to the build jig. I've seen a lot of pictures using the wing attach holes for the root end alignment, but not much on aligning and securing the tip.
Since the tip rib is full length, and outboard of the spar, it seem I'll need some kind of an arm which will go through a lightening hole and up to the spar.
I have a few ideas, but any pictures or thoughts for how others have done this would be appreciated.
I'm working on an LSA, but the solution should be applicable to all models.
Thanks,
John
Thanks,
John
