(bearhawk patrol)
It was mentioned once before on the forum, but I did not understand at the time. This may be model specific. I am working on the Patrol.
I thought that building on a table would be similar to builing in a wing stand. I have seen plumb bobs used between attach plate holes when wings are assembled completely in a wing stand.
In the case of assembling on a table - the attach point holes are not meant to line up.
The main and rear spars are parallel. The main spar will be on table surface. The rear spar is to be maintained parallel but has freedom to be moved up off of the table.
There are only two choices for the vertical distance. You could make the attach holes concentric. Or, you could choose the height to have the cord line parallel with the table.
Either the cord line or a line thru the attach holes could be made parallel with the table. The two possible choices are not parallel.
The dashed line in the drawing is the cord line for the wing section (there is no holes in attach plates they are drawn to make locating the wing cord between spars
