A suggestion has been made to get my wing steel parts galvanised before priming/painting. Is this a reasonable path to take?
Galvanised wing steel parts?
You would basically be doing the same job twice if you painted over the top of galvanising, both are just a protective coating.
As you probably know, galvanising is physically consumed as the corrosion attacks it [first] before starting into the metal. In a geothermal environment like yours, data I have access to shows industrial thickness galvanising is consumed in as little as 10 years of exposure [to the airborne chemicals]. In salt rich coastal environments, it also doesn't last long.
Basically that is anywhere in the North Island.... haha. Not really. Some places are much worse than others
Paint on the other hand, must be physically worn down or degraded by UV light before it becomes ineffective. Inside a wing, I predict that is not going to happen very fast.
