Probably old hat and covered in numbers vids, etc., but if roughing out lightening holes with a fly cutter seems daunting, and tin snips is a little tough on the smaller nose rib and aileron and flap blanks, an air nibbler does a quick job of removing the material to within a 3/16" or so of the finished edge, and at minimal risk (eye protection for flying chips).
I load the drilled rib blank in the routing template/rout cover sandwich, step outside (nibblers make a terrible mess), use a 1/4-7/8 step drill to punch a starter hole near one edge, then use the edge of the router template as the guide for the nibbler. Without that 1/4" hole from the fly cutter, I can even get a couple aileron and flap rib attachment angles out of each piece of the larger hole's scrap. Having the rib blank held in the router template/cover sandwich makes drilling fast and easy, while the edges of the template guide the nibbler cut to within a easily-routed-off margin (no deep routs in wide material).
DISCLAIMER: Yes - totally doable with with tin snips, fly cutter, CNC, etc. Pick the best option for your situation and available tools, but if you have a $23 Harbor Freight air nibbler handy and are already routing the ribs, it works.
