Holes through tubing
  • Holes through tubing
    Anybody got a tool or a process for debudring holes through tubing? The O.D. is easy, how do I get the burr off the I.D.? Tried drilling underside and reaming, that helped, still have a slight burr. Any ideas?
    Patrol
    There is such a thing as a blind deburring bit that you chuck in a drill. It has a retractable cutter that allows it to pass through the hole. I saw one at an RV builder's shop but have never purchased one, since they are expensive. What is the application?
      The empennage has weldments that slide on to smaller diameter tubes. Grease fitting holes through elevator hinge fittings is one example.
        I have used a deburring bit like this with good success.
        Shaviv Deburring Tool Replacement Blade B30 Simultaneously deburrs the inside and outside of holes up to 0.16 inches (4 mm) thick.
        Lee
        Patrol QB #312
        Buchanan Airfield
        Concord, CA
        • Camflyer
          Camflyer commented
          That's what I was thinking when I read the op question.
        If the tube is short, what about a rounded file applied parallel to the tube length?
          I just used a fine-cut round file as Jared suggested to knock the burrs down. I also used something like this to polish the inside of tubing that I had welded: https://www.eastwood.com/autobody/sa...=google&wv=3.1
            Not sure about the clearance but Paul (@alaskabearhawk) posted this video recently, would this work for you?
