Guys,
While I am waiting on tools to complete the lower fuel system install, and since I am fooling around in the area of the lower forward fuse, I would like to work on the "Cover plates for the clearance hole where the landing gear shock strut passes through the fuselage belly skin.".
Does anyone know the maximum compression of the shock strut spring? I'm thinking that I can disconnect the strut at the base of the gear leg and swing the gear leg out, while keeping the shock strut aimed at its anchor point, and when the distance from the shock strut to the gear leg equal maximum compression I will have the maximum angle of the shock strut.
Or maybe there is a better way.
Thanks,
Wes
Thanks,
Wes
