This fairing, especially where it wraps around the leading edge is giving me fits. As you can see in the pictures, there is quite a gap on the wing side. Material is .020 2024T3, probably should have gone with a softer alloy. I used a Lancaster shrinker in that area but was way too much of a gap to shrink. You can see puckers between clecos on the top of the wing that I was able to successfully shrink. When I installed the windshield I did my best to align the wing root area of the windshield up with the wings, but the windshield was larger, I tried to split the difference top and bottom. I've run out of ideas of how to fix this. I think I will have to layup fiberglass or carbon for this part of the fairing, I really don't want to go that route.
) you can glue/epoxy some 180 grit aluminum oxide cloth to the face of the jaws. You can get this as “emery cloth” or “plumbers sandcloth” at just about any hardware or big-box building supply. This will accomplish the same effect of gripping without the cuts the jaws normally make as tinman’s special jaws do (this is likely where he got the idea). Fairly easy to grind off and replace as needed with 5-minute epoxy. I used the Stewart Systems green glue for one small project and it worked fine, didn’t last forever but still works. Of course the tinman’s jaws are nice, and I may get some one day, but when you need a fast solution this may help.
