Looks like there are a variety of ways to fasten the kit provided Al stringers to the "U" standoffs and brackets welded to the fuselage.
(1) Cotter pins seem to be a good method - light and relatively easy.
(2) Rivets raise the question in my mind of whether to use a rivet on each side of the "U" and are there short pull rivets that are short enough to fit in the space between the stringer wall space and likely there will be an interference issue with opposing rivets.
(3) Screw and nut would work well but is heavier than a simple cotter pin.
So, I'm leaning toward the cotter pin solution, but would like to hear any other thoughts on the methods or techniques others have used. My single brain "brainstorming" could use some group assist!
