I have an IO-360, AFP fuel servo and using EFII boost pump. I surmise that you want to be able to measure fuel pressure downstream of both fuel pumps (boost and mechanical) and also past the last fuel filter prior to the "servo". How is this accomplished? Not making sense to me on how best to do this? Vans has a port fitting for the mechanical fuel pump which you could Tee a line to a pressure sensor. But, that doesn't get you pressure past the filter prior. Any thoughts would help! Thanks so much
Cheers Dave (from Maine)
