Welding 2025
  • Welding 2025
    I’ll start with the questions first and then the random thoughts.
    When setting up to do oxyacetylene welding:
    What size cylinders are other builders using?
    What length of hose are you using?
    Do you raise the outlet pressure to compensate for pressure drop?
    The reason I ask is because my shop is small, it would be most convenient to mount the cylinders to the shop wall and use 25 ft. hoses. This would enable me to reach everything in the project, including outdoors in front of the shop where I will start practice work and small part fabrication.
    Alternatively, I could use the 10 ft. lightweight hose and a cylinder cart if it really is best to be right next to the regulators, and if standard hose is too ungainly and pressure drop is unacceptable in the longer hose.
    The equipment I have so far is the Miller Smith Airline AW1A torch and tips and a rudimentary welding table. Since I will have to wrangle the cylinders myself into and out of the car, they can’t be too heavy. On an EAA forum thread, somebody said 80 cu. ft. of oxygen is enough to weld more than one fuselage. Can that be true?
    I imagine Bob still includes the photo demonstrating OA is good and TIG is bad in his booklet with the plans. But seems lately the debate over OA versus TIG has settled down a bit, both sides agreeing either method is acceptable when done properly. I’ve decided to pursue gas welding and am persuaded it is the easiest method for the beginner to start with. TIG will be an option if it seems necessary.
    My go-to guide is the EAA, of course, with gurus Earl Luce and Budd Davisson leading the way. I have a book and DVD and have bookmarked many EAA webinars, tips for homebuilders, articles, and forum discussions. With the passing of Kent White, tinmantech.com no longer seems to be available.
    There have been some good threads here on the forum also.
    Locally, I continue to search for instruction. The community colleges and trade schools all want students to enroll in certificate programs. So far I have not found auditing to be an option. The college of Youtube of course has a lot of valuable information. General Air Service and Supply offers one-day courses in various welding methods. Hopefully in May there will be an OA course available. Talking with the guys at General Air about regulators and cylinders and such, they view OA as something you use strictly for cutting, and insist that what I am talking about is brazing.
    My best bet is my EAA chapter where there are one or two old hands who may be of assistance. I attended a TIG workshop a while back conducted by one of our senior leaders. He’s also a Tech Counselor and presumably knows plenty about OA as well. Soon, when I have the basic setup assembled, I will make a public appeal to my chapter for assistance. I’d gladly pay for some one on one tutoring just to get me started on practice work safely and without bad habits.
    Frank Forney
    Englewood CO
    EAA Chapter 301
    I just use the small HVAC Port-a-torch size bottles. I did buy one extra oxygen and two extra acetylene bottles. Sometimes I wish I had larger cylinders just to I don't run out of gas mid task, but I've gotten by. I have a Meco midget torch with lightweight hoses and really like them, so much easier to hold and manipulate in tight spaces.
      Learned from Earl years ago.
      My oxygen cyl including the valve is 47 inches If I had to guess they call it a S, maybe 125 cubic feet (not including protective valve cover )
      My Actylene cyl including the valve is 38 inches I think it is 145 cubic feet
      same A1wa torch as earl used.
      I have never found the length of the hose to matter.
      I even connect a b size kevlar hose to the regular A size hose
      Make sure and get back flow flame arrestors
      You will find when you go to get a cylinder they will be brand new when you get them.
      Then on the first refill those cylinders are gone and you will have something much older.
      I think the industry says that you are only leasing them for a 100 years. I think all welding supply shops operate the same way. They have no choice. There is no way they can
      fill a tank when your pull up and keep track of which cylinder is yours.
      No matter what you do the oxygen and actylene run out at different times, and you are not going to see those new cylinders again.
      You have to be a bit careful if you buy cylinders from some place other then the welding gas supply store as they may not want
      to take your cylinders in trade
      You might even find that they do not have them in stock.
      Stan
      Austin Tx
        I have a Smith AW1A, light weight hoses connected to a 25' hose. I took a chance and bought 2 empty cylinders off Craigs list. Took them to the welding supply and they exchanged them for full ones, no questions asked. Now I'm golden, I exchange them when empty. I got big ones, oxygen is a K, acetylene is a KW. The whole rig on a cart takes up a lot of space though. Good luck.
        Patrol #30
