Welding 2025
  • Welding 2025
    I’ll start with the questions first and then the random thoughts.
    When setting up to do oxyacetylene welding:
    What size cylinders are other builders using?
    What length of hose are you using?
    Do you raise the outlet pressure to compensate for pressure drop?
    The reason I ask is because my shop is small, it would be most convenient to mount the cylinders to the shop wall and use 25 ft. hoses. This would enable me to reach everything in the project, including outdoors in front of the shop where I will start practice work and small part fabrication.
    Alternatively, I could use the 10 ft. lightweight hose and a cylinder cart if it really is best to be right next to the regulators, and if standard hose is too ungainly and pressure drop is unacceptable in the longer hose.
    The equipment I have so far is the Miller Smith Airline AW1A torch and tips and a rudimentary welding table. Since I will have to wrangle the cylinders myself into and out of the car, they can’t be too heavy. On an EAA forum thread, somebody said 80 cu. ft. of oxygen is enough to weld more than one fuselage. Can that be true?
    I imagine Bob still includes the photo demonstrating OA is good and TIG is bad in his booklet with the plans. But seems lately the debate over OA versus TIG has settled down a bit, both sides agreeing either method is acceptable when done properly. I’ve decided to pursue gas welding and am persuaded it is the easiest method for the beginner to start with. TIG will be an option if it seems necessary.
    My go-to guide is the EAA, of course, with gurus Earl Luce and Budd Davisson leading the way. I have a book and DVD and have bookmarked many EAA webinars, tips for homebuilders, articles, and forum discussions. With the passing of Kent White, tinmantech.com no longer seems to be available.
    There have been some good threads here on the forum also.
    Locally, I continue to search for instruction. The community colleges and trade schools all want students to enroll in certificate programs. So far I have not found auditing to be an option. The college of Youtube of course has a lot of valuable information. General Air Service and Supply offers one-day courses in various welding methods. Hopefully in May there will be an OA course available. Talking with the guys at General Air about regulators and cylinders and such, they view OA as something you use strictly for cutting, and insist that what I am talking about is brazing.
    My best bet is my EAA chapter where there are one or two old hands who may be of assistance. I attended a TIG workshop a while back conducted by one of our senior leaders. He’s also a Tech Counselor and presumably knows plenty about OA as well. Soon, when I have the basic setup assembled, I will make a public appeal to my chapter for assistance. I’d gladly pay for some one on one tutoring just to get me started on practice work safely and without bad habits.
    Frank Forney
    Englewood CO
    EAA Chapter 301
    I just use the small HVAC Port-a-torch size bottles. I did buy one extra oxygen and two extra acetylene bottles. Sometimes I wish I had larger cylinders just to I don't run out of gas mid task, but I've gotten by. I have a Meco midget torch with lightweight hoses and really like them, so much easier to hold and manipulate in tight spaces.
    • Frank
      Frank commented
      Judging from the photos you have posted, you scratch built a fine fuselage! I can imagine using a small welding setup like yours could be very easy to handle in and around the project.
    Learned from Earl years ago.
    My oxygen cyl including the valve is 47 inches If I had to guess they call it a S, maybe 125 cubic feet (not including protective valve cover )
    My Actylene cyl including the valve is 38 inches I think it is 145 cubic feet
    same A1wa torch as earl used.
    I have never found the length of the hose to matter.
    I even connect a A size(3/8) kevlar hose to the regular B(9/16) size hose
    Make sure and get back flow flame arrestors
    You will find when you go to get a cylinder they will be brand new when you get them.
    Then on the first refill those cylinders are gone and you will have something much older.
    I think the industry says that you are only leasing them for a 100 years. I think all welding supply shops operate the same way. They have no choice. There is no way they can
    fill a tank when your pull up and keep track of which cylinder is yours.
    No matter what you do the oxygen and acetylene run out at different times, and you are not going to see those new cylinders again.
    You have to be a bit careful if you buy cylinders from some place other then the welding gas supply store as they may not want
    to take your cylinders in trade
    You might even find that they do not have them in stock.
    Stan
    Austin Tx
    • Frank
      Frank commented
      Thanks Stan. My supplier sells small tanks and leases the larger tanks. The O2 tank you describe leases for three years at $300. Other people are confirming that hose length is not a factor. But I still wonder what outlet pressure people are using. Is it 5 psi regardless of hose length? The 10 ft lightweight hose is pretty pricey.
    • sjt
      sjt commented
      If it is 5 psi at one side of the hose it is 5 psi at the torch.
      The flow rate is not that high.
      The welding tip orifice is pretty small. acetylene is pretty hot.
      From my experience:
      As a rule the correct size tip is the one that will bring your 4130 to welding temp in 3 seconds.
      If it takes 5 seconds use a bigger tip.
    • jaredyates
      jaredyates commented
      I just set the regulator flow based on how things are going at the torch. If I'm full open on the torch valve and not getting enough fire, I tighten the regulator knob a little. If I barely crack the torch knob and am getting too much flow, I back off of the regulator. If the regulator did not have a low pressure gauge it would be fine.
    I have a Smith AW1A, light weight hoses connected to a 25' hose. I took a chance and bought 2 empty cylinders off Craigs list. Took them to the welding supply and they exchanged them for full ones, no questions asked. Now I'm golden, I exchange them when empty. I got big ones, oxygen is a K, acetylene is a KW. The whole rig on a cart takes up a lot of space though. Good luck.
    Gerry
    Patrol #30
    • Frank
      Frank commented
      Is that 25 ft hose a standard hose with B fittings and A adapters at the torch? Do you find the hose to be heavy and a problem? Or did you just get used to it?
    • geraldmorrissey
      geraldmorrissey commented
      My 25' hose is standard. And somewhat heavy. The lightweight Kevlar hoses shown in Stan's post are a joy. The lightweight hose look fragile though, I treat it with great respect. Because my cylinders are on wheels, I can get close to the work and often only need to unwind the Kevlar hoses.
    Check around at different welding supply stores?????
    $300 should be a lifetime purchase for an S cylinder 125 cubic feet.
    (Like I say it will be traded in for an old cylinder on your refill)
    Maybe it is different in your part of the country???
    Also, that is for an empty cylinder you will have to pay for the oxygen. I have not done it lately but the oxygen will be $75 to $100.
    I bought above from home depot. It goes for $345 these days
    NorthernTools sells something similiar for $245 but it does not have a rosebud or all of the tips.
    I think the hose is 15 feet. You would have to check but the above equipment uses the 9/16 b fitting
    Sooner or later you will want a rosebud and cutting torch.
    Maybe not on your airplane, but if you have a torch you will find something
    For my airplane I use a smith AW1A. I know you will need the aw201,aw203 tips
    I also use an "A" size (3/8) kevlar hose which is spliced onto the homedepot "B" size
    b.jpg f.jpg Forney 86152 Oxygen Acetylene Brass Fitting, Oxygen and Acetylene Hose Couplers, Adapters A to B Oxygen and Acetylene, Carded Pair
    The a to b fittings can be found on Amazon for under $16
    I do this just because the AW1A is small and light weight .
    Most importantly I do it this way because I am building an airplane to generate reasons to buy every tool I can think of.
    I have seen these for as low as $162 (weldingstore.com)
    You need at least two different tip sizes
    They go for something like $60 apiece
    If you go with this style torch get the aw201 and aw203
    Stan
    Austin Tx
      As you can see there are a lot of local variables. I have a set that is about 3-4 feet tall and then have a small portable set. For some reason I only run out of welding gas at 5:05pm on a Friday and having the two tanks gives a backup. Those little tanks have also come in handy for portability. The Airgas where I live is very flexible with core tanks. I take in some/any empty tank and they send me out with whatever I am after. I buy empty use tanks for around $50 and figure if Airgas ever changes their mind, I'll make some gongs for the shooting range.
      • Frank
        Frank commented
        Those cylinders make nice gongs. Yard sculpture and lawn ornaments are my backup plan if the airplane project fall through.
      Finally set up with a modest welding rig and have started to practice. Torch, tips, lightweight hose, flashback arresters, regulators, 92 cu. ft. of O2 and 75 cu. ft. of acetylene (purchased, not leased), full face mask, goggles, striker, gloves, tip cleaners, fire bricks, 1/4 plate for welding table and some 3x36x.062 and .040 4130 for practice.
      Cost me $1750 including shipping, other fees and taxes.
      So far I like using the full face mask, 1.5X magnifiers, and getting in close, just a few inches from the flame. Heavy cotton shirt, gloves, long pants, etc. and the cylinder valves and fire extinguisher are handy. The vinyl floor covering could become an issue. Need to test some scrap pieces, see just how flammable it might be. Thought about setting up the welding table just outside on the concrete but was advised that even a slight breeze can be a problem.
      A few hours in, I’m just starting to get some results. It’s very interesting indeed. On advice, I am cleaning the practice pieces with emery paper and acetone. The thing which puzzles me is the back side of the practice piece. I can see uneven penetration (which I can improve with practice) but on either side of the bead are thin raised lines of bubbles, some sort of artifact. What is happening? Also, there is sometimes a little flaking, almost as if the .062 is laminated and a top layer separates or becomes flaky.
      But a screen grab (attached) from an instructional video kinda shows the same thing.
      EAA tech counselor to pay a visit in a few weeks. He gives TIG workshops for our chapter but is experienced in gas. There may possibly be another chapter member or two who can help me. I’ll also try harder to find a community college or trade school course in oxyacetylene. I have a hunch that trade school courses will introduce gas welding as a short stepping stone to other processes and relegate o/a to cutting. But I’ll dig a little deeper. Also, there may be gas welding people in art sculpture or bicycle building worlds. EAA Sportair Workshop in gas welding not currently available.
      I feel I need some personal instruction, preferably from a gas welding enthusiast. But really, there is a wealth of instructional material readily at hand. I have the EAA DVD and book. There are also lotsa EAA online videos, articles and webinars. Budd Davisson is the most visible proponent and I have all his stuff. Earl Luce did the DVD and also has other video clips online. Dr. Joe Maj has some EAA videos.
      Some old EAA videos are not on the website but available on Youtube.
      And a wealth of other videos including this vintage 1920s, back when oxyacetylene was the modern method.
      This gallery has 5 photos.
      Frank Forney
      Englewood CO
      EAA Chapter 301
        on the topic of gas welding---- is there a place that sells a meco midget at a reasonable price now that the uber talented Kent White is no longer with us ?
        Tim
        • Bcone1381
          Bcone1381 commented
          A data point on the Meco Midge. It was my first welding torch. It is small, light and capable of fusing thin walled 4130 tubing. But I sold it and got a Smith AW1A because the Meco was kind of loud. When using it at the EAA Sport AIr Worshop I felt its volume high enough to be a bother to others welding quietly nearby.
        When using the Smith AW1A torch, has anyone needed a smaller tip than the AW201? Or with any torch, have you needed a tip smaller than .026 inch (71 drill size)?
        Reason for asking, I can practice open butt joints and the keyhole/pacman technique on 063 4130 okay. But trying the same thing on 040, the material melts and burns through so fast I can't manage. That makes me think I need a 00 or 000 AW200 series tip to practice that particular joint on 040 steel. But, since there are no actual butt joints like this in the project, and the point of the exercise is to learn control and consistency, why bother buying an expensive tip I may not actually use on the project (~ $100 bucks on ebay)?
        I am learning that each type of joint has its own heat requirement. Open butt joints seem to require the least. Outside corners a little more, and T-fillet require a LOT more BTUs. So with the 063 material, I use the AW201 for the butt and corner joints and then find the AW205 works best for the T-joint. Lap joints also seem to require a surprisingly hot flame.
        And I haven't even started trying tubes yet!
        I did get six hours one-on-one instruction (1 1/2 hour sessions) from community college senior welding instructor, which answered a lot of questions. One thing that sticks in my mind is our discussion of real world versus ideal world. When it comes to the T-joint for instance, ideally we want penetration as in the EAA diagram. But in the real world...?
        Cutting through some of my practice pieces, clearly not getting consistent penetration into the root of the joint. I tried polishing and treating with naval jelly (phosphoric acid) to delineate the actual penetration, but it didn't seem to work.
        Frank Forney
        Englewood CO
        EAA Chapter 301
        • sjt
          sjt commented
          As a reference:
          If I have the correct size tip,
          If I have the correct psi
          then when I point the oxy acetylene at metal it will make a puddle in 3 seconds (not 4 , not 2) If it does not then I have the wrong size tip.
          If you are getting a puddle in 3 seconds then the next thing is the rg welding rod.
          You use the rod to cool the puddle on which ever side is getting to hot. Put the rod in the puddle -as needed -to quench the puddle and keep it under control.
          when welding two plates butted together, you can not start at the edge. You have to start into the seam maybe a 1/4 inch.
          When you get to the end of the seam you have to apply the flame to the welding rod and follow it up. It will drop the last drop of metal at the edge.
          Now that you have lots of metal to absorb heat you can turn it around and go back and get the begin by again starting a puddle and applying the flame to the welding rod and tracing the welding rod up .
          Tubes are a bit of a challenge because the scallop out section of the tube has a thinner section. Try to start the weld with equal amount of metal on both sides.
          I use the 201 and the 203
          stan
        • sjt
          sjt commented
          I wrote an article for my chapter after attending a sports air workshop
        Using a Meco Midget the smallest tip I found a need for was N1, which is drill size 70.
          Thanks for the tips, Stan. And a very good article you wrote for your chapter. I’m having a little trouble with the coping calculator link, but I’ll get it eventually. I’m going to forget about the 00 and smaller tips for now. So, back to practice and more practice!
          Frank Forney
          Englewood CO
          EAA Chapter 301
            Frank--- I remember reading somewhere --- that when you set your acetylene presure with the regulator--- there is a maximum safe pressure. Mine have the area above safe painted in red. I dont know if they are all that way. It was said that inside the regulator if the pressure is above that maximum-- the gas can spontaneously explode inside the regulator. That would be bad.
            Also--- every gas welder should be told- --- NEVER---- EVER---- lay and acetylene bottle down on its side either in use or in storage. The tanks have a porous matrix ( like concrete) inside and that is filled with acetone. That combination keeps the gas from detonating spontaneously. if you lay the tank down- the acetone can be leaked out or burned-- and if enough gets depleted from the matrix inside---- The tank can detonate. I remember seeing pics of one that did that a a house in austrailia. it blew the house completely off the foundation and there was nothing left of the house except match sticks. The people happened to be away- so no one was killed. The man said he had layed his tank down on its side when not in use.
            (acetylene is the only gas that uses this system AFAIK--- so you are oK to lay other types of tanks down.)
            Also--- dont clean you parts to be welded with brake cleaner. When heated or exposed to intense UV from an arc- it maked phosgene gas which was a nerve gas from world war one. it will burn your lungs up and kill you dead. 1/10 of a drop can kill you------ alcohol and acetone are fine to clean with.
            NO BRAKE cleaner !
            Tim
              Thanks Tim. It scares the hell out of me. What I have read is this: acetylene in a pure gaseous state is dangerously unstable above 15 psi. The tank pressure may read 250 psi but this is safe because the acetylene is dissolved in acetone and held in a porous filler material. On the other hand, the Miller handbook which came with the torch states that failure to force a sufficient amount of fuel through the tip will cause the tip to overheat, leading to a possible flashback or backfire. The same handbook recommends 10 psi output at the regulator. But the Victor handbook recommends 3-5 psi for the size tips we use, which is more in line with the consensus among aviation welders. Currently I set the output for both gases at 4-5 psi. I still struggle a bit to understand how outlet pressure and torch valve adjustments work together to produce the desired flow rate. Bottom line: I will not get anywhere close to the red line 15 psi and I'm not going to try 1 psi either. I did get the Smith regulators which read accurately in the low range of pressures.
              OSHA, DOT and all regulatory agencies say to never transport acetylene cylinders horizontally. Reading what people like us have to say about that is a different matter. Another area of mixed opinion. I asked my supplier when I got my cylinders (75 cu ft acetylene) about transport and was told that customers transport their acetylene horizontally all the time and that's what I did. I secured the tanks in the shop and didn't install the regulators until the next day allowing the acetylene contents to settle. Soon I will be going back for an exchange of tanks and I will decide then about vertical transport of the acetylene. It would be easy enough to strap the acetylene tank to the back of the front passenger seat set upright. I never would have thought to store the tank, much less use it horizontally. But I guess some people have.
              I use a scotch brite wheel to clean up the steel and acetone to remove sharpie marks. Could be overkill but my EAA welding guy says it all has to be 100% clean. Keep everything oil free as much as possible. I need t figure to what extent I need to clean the inside of tubes. I used a dish soap solution to check for leaks but was advised by my welding instructor to buy a leak-check solution from welding supply, since many dish soaps contain problematic oils.
              I need to get a 20 lb ABC extinguisher instead of the little BC extinguisher I have. Otherwise I think I'm okay for safety at the moment.
              I keep coming back to the various tensions and experts don't all agree on everything. Oxyacetylene welding may be equal parts science and art. And there is the overriding tension between the ideal and the practical, which is inherent to all parts on my project so far.
              Frank Forney
              Englewood CO
              EAA Chapter 301
                it is NEVER safe to have the tank in a horizontal position. if the acetone should leak out a faulty valve-- you could be dead. Simple as that. saw a pic on one of the welding forums of a tank a guy left horizontal in his garage. It blew the house off the foundation. When the people arrived home - there was ONLY a concrete slab remaining.
                Make SURE you have check valves between the torch and hose ends. if the flame "pops" --- that is the flame jumping inside the tip and possibly up the hoses. and then through the regulators into the tanks. The check valves stop this ----
                  Gonna guess most folks don't have a rack in which to secure a decent sized bottle even if they have a vehicle that can handle the vertical carry. That suggests delivery, which for non-industrial folks can be pricey depending on locale. And that goes to my observation that - with good, cheap (usually not words that go together, but in this case do) DC TIG welders - TIG and gas welding costs have converged to parity. Going to guess that folks that weld up their own airplanes to go fly probably have no trouble living with any safety issues related to gas handling, etc.
