Some I gathered some facts about flooring for the Patrol (22.25 sq ft area), and considered 1/4" Baltic Birch, Composite Flooring, and Aluminum.
-A Baltic Birch floor would weigh 19.58 pounds.
-A composite Floor 1/4" 2 ply from Javeron would weigh 10.23 pounds
-An Aluminum floor of .032 weighed 10.26 pounds.
-An aluminum floor of .025 weighed 8.01 pounds
-Installing .020 under the rear seat between station D-E with .025 AL in the rest of the floor weighed 7.64 pounds.
-Istalling .016 between D-E would save another .3 pounds. over .020 AL.
I did not think of noise reduction with silicone, but I thought of Cork, which does not absorb water.
Some would argue that Aluminum is inferior due to noise and other factors. Cessna, Beech, and Piper used a lot of Aluminum and no one complains too much.
Aluminum does not make noise unless it vibrates, but neither will it suppress noise on its own. To add suppression of noise from other producers like exhaust would add .15 pounds per Sq Ft. if I used Sound Proofing Mat from
www.supersoundproofing.org So, I thought that product was pretty light and will consider installing it.
It surprised me that I could save 12 pounds by not installing wood, and that Aluminum compares favorably with Composite Flooring for weight savings.
Patrol #303
