Has anyone got a engine mount from Mark for a o-360 that could give me a measurement from the center of the bottom bolts to center of the top center mount ? Plans only show the 4 bushings thanks Wes
Engine mount bushings
I don't have Mark's mount but I have two points/questions.
Doesn't the O360 mount not use the 5th (top center) mount? So you'd need the dimensions from someone with an O540 mount.
Second, I don't think you could get close enough with just the dimensions. If you are going to use one of Mark's mounts then you should just buy it now and install the firewall bushings to match the mount.Scratch Built 4-place Bearhawk. Continental IO-360, 88" C203 McCauley prop.
I have Avipro 360 engine mount. The legs flex some so measurement from the center of the bottom bolts to center of the top center mount can be suspect when not attached. The Avipro mount fits my airframe and I measured from the center of the bottom bolt on airframe to center of the top center mount on airframe and came up with 28 1/16th inch.Attached Files
