I called Steen Aero Lab to order the tail flying wires for my 4-place Bearhawk. They took my order but said they could save us a lot of money if they could send in at least 5 orders. I then talked to Mark Goldberg and he suggested I put this out on the forum to see if anyone else is ready to order the tail wires. The same wires are also used on the Patrol. If so, please call Steen at (321)725-4160 and place your order. I believe the Steen rep said after they place the order there is still a 5-6 week lead time to manufacture.
Steen tail flying wires
As an alternative to the Steen/Brunton wires, I used 5/32" 1X19 stainless cables with MS21259 stud (left and right) swaged ends. Don't use the MS21260 turnbuckle ends as they have less threads for adjustment. Several of us have used this method and it is "Bob" approved! If you are going with the round wires anyway, this will save you a LOT...
Collin
I got my flying wires from the guy in NZ. I think he matched the Steen group price and lead time was about the same, 6ish weeks. If I could go back and do it again I'd do the same as what Collin did and use cables with rotary swaged ends.Scratch Built 4-place Bearhawk. Continental IO-360, 88" C203 McCauley prop.
I went with the Steen/Brunton wires. Flat for the uppers, round for the lowers. I would have preferred the aerodynamic "flat" wires everywhere, but there is some evidence (Piper ADs, etc.) that round wires survive hits from gravel and other objects much better than the aero wires.Jim Parker
Don't know if it would work for the four place or Patrol, but for my LSA I was able to dig through documentation on the Univair site to come up with standard wires to fit. IIRC, it was a mix of Citabria and Cub wires. The set without ends was around $225 and were available off the shelf.
Just for reference, I was involved in the group buy back in March 2015.
$120 each for streamlined wires
Clevis ends, 8 required.
$32/ea for stainless
$20/ea for cad plated
Shipping was another $50
April 2007 issue of Bear Tracks has drawings, manufacturing, and installation Bob Barrows round tail wires made of 1/4" 4130 steel rod. It includes both the tail wires and the tail wire attach fittings.
Additionally, I have wondered about 1/4" streamline tubing from the Hobby Express might be an idea to use compete with the streamlined flying wires for drag reduction.
$4 for a 35" piece....http://www.hobbyexpress.com/aluminum_tubing_423_ctg.htmLast edited by Bcone1381; 09-15-2016, 12:04 PM.Brooks Cone
I'm pretty leery of that for critical structural members.Originally posted by Bcone1381 View PostApril 2007 issue of Bear Tracks has drawings, manufacturing, and installation Bob Barrows round tail wires made of 1/4" 4130 steel rod. It includes both the tail wires and the tail wire attach fittings.
I think the idea is to place the streamline tubing over the round wires for a drag reduction fairing, non-structural. Just have to figure out an easy way to inspect what is under the cover.
Ahh yes of course Patrick, I remember the discussion now. Also the need to secure the tubing so it can't rotate and cause flutter of the cable. Thanks for the reminder.
