Wonder if anyone is installing air vents for rear passengers, could not find any posts or pictures.
Air vents for rear passengers
I've ridden in a Patrol that had simple circular vents in the window......seemed to provide good airflow.
I think a NACA intake under the wing with a SCAT duct routed aft of the windows would be a good bet.
Where we fly (ambient temps from 35*C to -5*C at sea level, -15*C at 10k ft), we seldom have the problem that it's too hot in the back. Its the cold which causes problems, especially in the back. I haven't found an idea for heating in the back which works for me (biggest criteria is weight - I don't want ANY extra)
Pat, could you post a picture(s)?Dave Bottita The Desert Bearhawk
Project Plans #1299
As I mentioned in a comment above, I was planning to put a Vans NACA in the wing root area between the ribs in the .032 skin, but Bob said he didn't want to have any holes there for structural reasons. My next question for him was "So, if I might have already cut a hole there, what should I do?" He suggested I patch it and that's what I did. I have purchased a set of vents like Mike posted above, but have yet to install them. I have not yet mastered the weather stripping issue, so our whole cabin is so drafty we haven't really needed them yet. My project before this winter is to seal the gaps and install the twist vents, planning to place them as high as possible in the rear windows to take advantage of the high pressure in intersection of the wing and fuselage.
