Hey All... Hangars are an expensive luxury in Alaska so my BH will most likely be parked outside. I always worried about water getting into the wing through the filler neck opening in the top wing skin. Does anyone have any thoughts on the most effective way to seal this opening? Alternatives? Thanks...
Fuel Filler Neck Sealing
How does that one drain fuel? it seems like it would have a little collection point.
The lip is almost flat when pressed against the doubler on the inside of the wing skin and the main body fits tight to the filler neck. The gap left is only the space between the skin and neck. As the lip is flexible the seal does not transfer any loads to either the tank or skin to promote wear. They are made for grease, oil, gas etc.and are only 3 or 4 dollars ca each,
