Wondering if any of you had any "I wish I'd have welded a...." moments after getting too far into it to want to weld again. Please add to the list of what I'm thinking already if I missed something
- tabs to strengthen throttle, mixture, carb heat, prop control knob attach points behind dash
- tabs to support an under dash tray to hold electronic misc (saw someone put a horizontal tray in the triangle V under dash front left and right).
- tabs for dome / interior lights
- tabs for gopros (interior and on tail)
- skylight framing
- possibly cut out/ reposition gear leg fairing to accomodate future large bush tires (anyone have experience on largest tire with good clearance with factory gear legs?).
- tabs for battery mount and ELT support
- tabs for possible wiring harness routing support (not sure about where this would be "needed."
- additional fairlead stand off to raise trim tab cables slightly above horizontal aileron cables.
- Rear float fitting attach point, external pulley attach point or fairlead to route rudder steering cables from rudder fwd towards rear attach point, veritical dorsal fin fwd attach point.
What am I forgetting?
Thanks!
Brad
- skylight framing
Thanks!
Brad
