I'm ready to start building fuel tanks. I have tank fittings from Spruce, but not sure what the proper way to mount these is. Does the whole fitting get welded on the outside of the tank, or do you cut a hole the size of the central part and most of the fitting is inside the tank. I've enclosed a photo of the fittings. Also, I believe Kent White at one time said the fittings and rivets could be aluminum brazed instead of welded. Has anyone used that method.
Rod
Rod
