Hinge part number cowl doors
  • Hinge part number cowl doors
    Is ms20257 piano hinges sufficient for cowl doors or are ms20001 hinge required. Thanks. Aircraft spruce piano hinge
    I used 257 hinges.
      257 for me as well. No issue after 100 hrs.
        Thank you. Thats what i used but began second guessing myself.
          Not sure but this may be a related topic of interest:
          This is a photo of a design flaw. Do not use 9 #3 squeeze rivits to hold you cowl doors on, they can fail. You need at least 20 #3's here!! 5 of the 9 sheared off
            I did see that. I have 20 rivets and will be installing a doubler beneath top hinge at doorskin
              More piano hinge questions: should the doubler cover only the fixed leaf of the hinge (the top) or both the fixed and articulating leafs?
              What width of hinge are people using? I see 1-3/4” and 2” at ACS. Thanks.
