4-Place - Fuselage dimension help request
  • 4-Place - Fuselage dimension help request
    Hello,
    I've been sitting on plans for a 4-place for a number of years. I need to get past a few blockers and get this thing moving. Could I ask a few questions?
    On page 17B, I'm having trouble finding critical dimensions.
    Specifically, the vertical height of these locations in the green circles.
    1. vertical height of the point above B in reference to datum
    2. Vertical height of S in reference to datum
    3. Vertical height of point above D in reference to datum
    4. Reading Eric's build manual, it appears the door sill must be 15" from the intersection above B to S and parallel with the lower longeron. I'm not finding that figure in the dimensions on the plans?
    5. (See #2 above) There's a dimension for C-S that appears to show the distance from C to S as 8" on page 19B below:
    What's not clear to me is if 8" represents the flat distance from C to S, or the vertical distance from the bottom longeron perpendicular to S which is a longer leg of the right triangle since C-S is at an angle. Since this is a station plane diagram, I feel like S is exactly 8" in height above the bottom longeron, not the distance from C to S which is undocumented as an exact length. I don't know how to interpret this one without asking. Any thoughts on what I'm looking at (length of material, or height of station above datum)?
    6. As I am now searching for the lean-back angle of C-S in reference to the lower longeron, I can see plans page 31B which references the flap handle (no screenshot here) and I can take a pro-tractor the old fashioned way for the angle. Ideally, I'd like to use CAD and get the right inputs and validate with a protractor.
    On page 29B, it shows the control stick mount where C-S is perpendicular to the S-D support diagonal at apparently a right 90' angle. The original side view of the fuselage in my first screenshot certainly does not appear that this is a 90' right angle. I can mock this up with CAD using this 90' degree angle and work the problem, but I need to constrain either the length of C-S or height of S as 8" from lower longeron, whichever is accurate. -see question 5.
    7. Another question, what are the horizontal dimensions in respect tot he center line for locating these diagonal intersections on C-S? I don't see them referenced anywhere in the drawings for the B model. Is this critical, or eyeball it?
    8. I have the same problem locating the dimensions for the top frame layout between P and O on page 18B. I'm not sure this part really makes a lot of difference, but i'll ask.
    Thanks!
    James
    Hi, James,
    I don't have the 4B plans, so I'm going off of my 5 plans. I think many of your answers for # 1, 2, 3, 7, & 8 are going to come down to pulling out a scale (or protractor) and making the actual measurement from the plans. All of the diagrams you referenced have either a scale noted in the corner of the plans or scale as noted on the individual diagram. For #5, on the model 5 plans the distance referenced is the flat distance. I verified this by measuring C-S on the control stick mount diagram.
    Sorry I couldn't be of more help.
      Buy an engineering scale and use that to determine the measurements. The plans are exact and scale only off the plans, not any photocopies.
      • Sir Newton
        Sir Newton commented
        100% Only scale off the original plans.
      Ok, will give this a shot. Good news is, there's only a few items I'll have to scale from plans and I thank everyone for the advice. Will get this thing started.
        Here are a few examples. The question that comes up on occasion: "Is the measurement to the outside of the tube...or inside...or center?" All the drawings, unless specifically noted in the plans by Bob, are tube centerline to tube centerline. Hope this helps...
          Those were good questions---- ones I might have asked in the near future if I have to scratch build it-----
            does anyone have a close up pick where the longerons come into the firewall ? how that is fitted is not shown on the plans....
              This one might get you a view you can use. About 5/6 down the page.
                Also this one and the next four entries or so from Paul's build log.
                  Thanks to Chris for pointing me into the right month and year to find my photos! Hope this helps.
