Thought you guys might like to see how I have bent these aluminum extrusion stringers so they are happy to wrap a little to the bends required. Not very precise, but it seems to work OK. The stringer wants to bend sideways also so attention is required to keep them straight. I just stand on them and use my weight. But if they bend a little sideways they can be straightened easily. Just to take some of the stress out of the stringers where they have bends. Mark
aluminum stringer bending
I saw several different posts on bending stringers. Some made of metal and some made of wood. I took ideas from others and quickly threw this together with a piece of plywood and a thin piece of poplar. I was going to put another piece of plywood on the outside to make a sandwich but I discovered it was not necessary. The stringer material did not twist at all. The bottom round piece of poplar has a 4" radius. I marked the stringer where I wanted bends and pulled the stringer down to make a bend. Very easy to work along and add a bend. You can also take a little bend out by turning the stringer around.
IMG_2457.jpgJohn Snapp (Started build in Denver, CO) Now KAWO -Arlington Washington Bearhawk Patrol - Plans #255 Scratch built wing and Quickbuild Fuselage as of 11/2021. Working on skinning the left wing! -Ribs : DONE -Spars: DONE, Left wing assembly's: DONE., Top skins : DONE YouTube Videos on my building of patrol :https://m.youtube.com/user/n3uw
