aluminum stringer bending
  • aluminum stringer bending
    Thought you guys might like to see how I have bent these aluminum extrusion stringers so they are happy to wrap a little to the bends required. Not very precise, but it seems to work OK. The stringer wants to bend sideways also so attention is required to keep them straight. I just stand on them and use my weight. But if they bend a little sideways they can be straightened easily. Just to take some of the stress out of the stringers where they have bends. Mark
    Sometimes it is the simplest ideas that are the best...
    Jim Parker
      thanks for that tip Mark Im almost to that point in my build and was thinking about how I was going to do that.
        I saw several different posts on bending stringers. Some made of metal and some made of wood. I took ideas from others and quickly threw this together with a piece of plywood and a thin piece of poplar. I was going to put another piece of plywood on the outside to make a sandwich but I discovered it was not necessary. The stringer material did not twist at all. The bottom round piece of poplar has a 4" radius. I marked the stringer where I wanted bends and pulled the stringer down to make a bend. Very easy to work along and add a bend. You can also take a little bend out by turning the stringer around.
