Thanks to all of you who have been providing feedback to the kit manual in progress. If you have a quick-build kit and are not yet set up to help, please send an email to web@bearhawkstore.com and I'll send directions. I thought I'd start this thread so that I can provide updates on what is published so far, what I could use help with specifically, and so that you can make specific requests for topics that need more coverage.
First, here is a list, updated as of April 2018, of topics.
Currently Published:
Kit builder support
Types of threads
Prerequisites
Workshop and Tools
assembling shock struts
Nicopress
Fuel and brake lines
Drilling
General aluminum handling
General riveting
General Steel
General kit welding
General fiberglass
Wing inspection covers
Edge Rolling
Routing Fuel lines through the wing root
Installing Nutplates
Fuel Tank Straps
Cutting the Fuel Tank Filler Neck Hole
Installing the Gear onto the fuselage
Installing brake calipers
Brake Line Hardware
MLG Alignment
Unpacking the Kit
Unpacking the Wings
About the Kit builder Manuals
Installing the tailwheel (leaf spring)
Casting elevator balance
Selecting tires 4-place
Engine Selection Tips
Installing the horizontal stabs
trim tabs
Installing the elevator and rudder
Elevator trim cables
4-place stick installation
4-place rudder pedal installation
Installing the flap system
installing 4-place floorboards
Elevator Trim Torque Tube and Horns
Drilling wings to the fuselage
Installing the Firewall
Boot Cowl
Instrument panel
Cowling
Brake lines and pedals
Cabin Ventilation
Fuel System
Instrument panel
Some of the above need further review and more pictures, especially the boot cowl and cowling. See below for specific photo requests.
The following topics are in the queue, not yet published but at least on the radar:
Doors
windshield installation
Windshield fiberglass fairing
Installing the aluminum formers for the boot cowl
Interior and Upholstery
Fabric Covering
Engine Mount installation
Engine Installation
Baffles
Oil Coolers
Exhaust Systems
Fuel Sight Gauges
Aux tanks
Wiring
Pitot/Static
Lights
Flap and Aileron Mounting
Aileron Cables
Flap Cables
Flap Torque tubes
Build wing struts
Aileron Counterbalance
Fuel Flow Test
Weight and Balance
DAR Prep
What topics need to be added to the queue?
Kit builder support
Types of threads
Prerequisites
Workshop and Tools
Nicopress
Drilling
General riveting
General Steel
General kit welding
General fiberglass
Edge Rolling
Fuel Tank Straps
Brake Line Hardware
MLG Alignment
Unpacking the Kit
Unpacking the Wings
trim tabs
Boot Cowl
Instrument panel
Cowling
Cabin Ventilation
Fuel System
Instrument panel
Doors
Fabric Covering
Engine Installation
Baffles
Oil Coolers
Exhaust Systems
Fuel Sight Gauges
Aux tanks
Wiring
Pitot/Static
Lights
Aileron Cables
Flap Cables
Flap Torque tubes
Build wing struts
Fuel Flow Test
Weight and Balance
DAR Prep
