It has been a long time since I flew with a center stick. Any idea about where the stick should sit, for and aft, with neutral elevator? I guess distance from the panel would be an easy measure. I am making up elevator cables. I know it can be adjust a bit later with the pushrod.
The plans also call for +35 -20 degree elevator travel. I am guessing that means you have to offset the elevator bell crank a bit.
I am about average height 5 11".
