Did anyone figure out how to remove this backlash / free play fore and aft?
It seems to come from the spherical rod end bearings and also from the clearance at the stick mounting brackets.
I have another backlash issue left and right because there's a tiny bit of slop in the brackets where the sticks bolt on. A small clearance down there translates to quite a lot of backlash at the top of the stick where the grip is.
If I were building again - I would make sure I drilled the bolt holes for the stick mounting brackets *slightly* out of line, L and R, so the bolts pull those brackets hard up against the stick's torque tube welded flanges / bushes.
I don't really mind it, but I do notice it sometimes, now that I'm used to the feel of the plane.
