Sooooo much variation to fuel system install. Makes it hard to compare fuel system issues between builders because every one is a one off, including mine, which looks nothing like any of these.
SPRL fuel selector and gascolator install.
I went ahead and cut an access panel this morning, in the stainless tunnel. I still need to make the cover. Problem is we are in a lockdown here in NZ so I can’t get supplies and I don’t have any stainless sheet. My question is, could I make the cover from .025 or .032 aluminium sheet ? Thoughts appreciated.
76E8EECA-DBBC-48F6-830B-7812BF7C1892.jpegNev Bailey
Surely the tunnel is made of stainless steel for a reason?
The tunnel has more direct airflow through into the cabin from that area where the hole is, so you want to ensure there is not any exhaust gas getting past the tunnel panel. and rising up past the pedals I would suggest a gasket.
Yes, hence my question. But I think given the proximity of the cover being aft and inside the exhausts the heat should be minimal. There’s .025 sheet aluminium 10mm further aft, followed by fabric all at a safe distance.Originally posted by Battson View PostSurely the tunnel is made of stainless steel for a reason?
This is a very relevant point given the fuel drain hole. The cover is easy to seal around the edges, but the drain hole not so much. Any suggestions appreciated.The tunnel has more direct airflow through into the cabin from that area where the hole is, so you want to ensure there is not any exhaust gas getting past the tunnel panel. and rising up past the pedals I would suggest a gasket.
Here’s where I’m currently at (the other hole is for the VHF aerial between the exhausts - it has a gasket) :
7B050F80-A949-4EAF-847F-2756377B8A1F.jpegLast edited by Nev; 08-25-2021, 01:56 AM.Nev Bailey
Following on from the above discussion, it does seems that exhaust is finding its way in around the gascolator drain valve. I've now sealed the top of the oleo struts pretty well, and also the top of the gear legs, and around the fire wall. I've been taping over the hole after draining fuel but I need a more permanent and functional solution.
One idea is to make a hinged flap with a rubber seal, held closed by a Camloc.
I'm wondering if a simple small gurney flap in front of the hole will cause cabin air to be drawn out (like the cowling exit cooling lip) rather than being forced in.
Thoughts ?Last edited by Nev; 12-26-2021, 11:50 PM.Nev Bailey
Nev, I have a 250 comanche. The fuel strainer is in the belly and it has a little door that I open to access the drain. Here is a link to one on eBay so you can see what it looks like. Similar to an oil door on some cowlings only smaller.
Lot of ways to plumb the fuel selector. This arrangement put the gascolator in a good position. I am using wood floorboards and split them down the middle under the pilots feet for easy access to all the plumbing and brake rigging.
The 5 kit has a nice setup, with just a single fitting in between the fuel selector and gascolator. It should make installation much easier, but I have a couple of questions.
1. Do you use any sealant on the fittings that go into fuel selector.. the ones that have the O-rings on them?
2. Torque wrench with a crows foot, or the hand tight & another 1/4 turn method? With the selector and gascolator in the right orientation, I doubt I could get another turn on it without breaking the fitting.
The fitting with the O-ring is called an O-ring Boss Fitting. (ORB) They don't get any sealant. The O-rig seals the joint.. Make sure the O-ring gets inserted fully into the valve. I had a slight leak with full tank of gas after installing my valve, and I had to give it another flat with a wrench to get it to stop. I think the machining was on the edge of the specs. All pipe fittings get sealant. They are designed to be sealed with sealant and can see the white sealant in Post #22 on some of the NPT threads, like the Gold Cube.Brooks Cone
