Howdy - Like most IO540s, I suppose, I have an alternator and starter on the front that I need to run wires to. My understanding is that those wires need to be separated from the sensitive sensor wires (CHT, EGT, etc). How have you all run and secured all these wires? Any pictures?
Also I have seen a lot of ignition leads for the lower plugs secured with the bottom screw of the engine valve covers. Mine have a pretty big lip and I'm not sure if its OK to cut off a section of that lip to attach a clamp of if everyone is just stacking washers to get past the lip on those covers. I have other ideas, but clamping there does look simpler than what I'm doing.
Cheers!
Cheers!
