Chris, for me that is a reason enough not to do it. On an air cooled engine, you can only leak oil or fuel. Either leaking on the windscreen is a disaster.
Cowl Flaps
Battson how did you actuate your cowl flaps? I don’t want to use an actuator, and am struggling to find certified examples for inspiration.
Here is a couple pics of my cowl flap installation. We fly in temps from 100f+ to -10f on floats wheels and skiis so cowl flap is a must. Used a Ray Allen actuator PN B6-11T
I used this dual end push/pull cable...https://acsproducts.co/our-products/...-lock-control/
With these wiregrips at the ends...
Wire Grip WIRE GRIP - Is a unique fitting which securely attaches to solid wire end push-pull cables. Uses a
There's a white knob to the right of the mixture control pushed all the way in to open the flaps. Works great mechanically and I have very good temperature control. IMG_6017.jpg IMG_6022.jpg4-Place QB kit #111. First flight May 2022.
IO-470 - 260hp
