Hi Everyone. I'm hoping some of the more experienced builders can help me out. I recently bought a scratch built 4 place with an IO-390 up front. I've upgraded to 29 inch ABW's and had to install a couple of heavy auto exhaust resonators to replace cracked exhaust mufflers. It already felt quite nose heavy one up, but now it really is. Engine idle and it won't flare at less than 60 knots or so.
Anyway, obviously I need to get a set of scales and re do the W&B, but I've read that this is a common issue with the Bearhawks so was interested in how other people manage it. The forward CG is great for when I want to load up the plane, but I'd like to have the same characteristics 1 up without having to put 80lbs or so of ballast in the baggage compartment. Has anyone played with adding removable/adjustable weight to the tail or are there any other suggestions? Does anyone have any guidance in terms of what the 'ideal' CG is. I guess by ideal, I mean far enough back where you can stall it on with a decent amount of back stick left at engine idle.
Nick
Nick
