Before I fly my almost finished Pacer.... will be installing clear teflon tape to the fabric surfaces and painted steel/aluminum surfaces.....maybe 1/8" beyond the door skins.  I'm also going to install between the lower boot and cowl... across the top of the boot cowl....butted against the antichafe tape.  Might turn a little yellow over time?  I'm also installing the same automotive film used to prevent rock chips on lower fender panels.... that film will be applied to the front sides of the Maule oleo gear struts and PA18 gear legs.... thicker black rubber stuff to the leading edge of the horizontal stabilizers.  I used urethane tape...the stuff used to seal steel siding/roofing panel where the boot cowl trailing edge attaches....then carefully removed the excess that squeezed out... hopefully will prevent the edge from working into the paint/fabric.
Mark M.
					Mark M.
