Looking to get my elevator balanced and I'm wondering what's a good way to close out the section with the profiled rib so I can pour the liquid lead in and not have it leak. All the examples I've seen have been on the flat elevators which is easy to clamp a piece of plywood to, but it doesn't look like that'll work with mine. Thought I'd see what others with the model B profiled elevators have done.
Casting Lead Balance With Profiled Elevator
Tags: None
I didn't know the elevator was profiled on the 'B' Thats pretty cool. I wonder if there is a significant difference.
I'd think a sheet of 1/4" plywood would do the trick.Scratch Built 4-place Bearhawk. Continental IO-360, 88" C203 McCauley prop.
I was thinking about thinner plywood too but the sheet metal could work as well, I have plenty of spare around after swapping my firewall and floorboards. Was thinking of layering aluminum foil to make a kind of gasket, the ribs are fluted too so I need a way to get a good seal. Oh, I also have to plug the lightening hole in the rib web as well...
Quite curious as to how other 'B' kit builders have done this.
Attached a pic, you can just see the section. The rib is easy to bend too so it can't take much force.
IMG_20171220_233828.jpgLast edited by Archer39J; 12-25-2017, 05:29 PM.
On the patrol I skip welded an upper and lower triangle shaped piece of thin steel to the rib and tube at the front. I flanged the open/rear edge and the pieces were flush to the structure. Poured the lead in. If I need to remove some I can drill through the rib and chew out some for correcting the balance if I had to. I am a little on the heavier side of what was suggested. Not sure how it would look with the profile rib but I can't see the assembly under the fabric.
I bought a profiled stab set and poured lead a few months ago. I clamped aluminum sheet on top and bottom and screwed a small piece on the inboard side. I also put some screws in the curved leading edge for the lead to grip but in the attached picture the aft screw wasn't inside the lead and the middle screw was barely inside the lead.
This method worked ok, but sheet aluminum obviously doesn't do compound curves and the resulting lead profile didn't perfectly match the desired fabric profile. I don't think it will be particularly noticable in the end result, but that is a couple years away...
I have the Model B wings and tried cardboard and plywood and both times it leaking onto the hangar floor. I tried several things to stop the leaks with no luck. I finally welded some thin steel plates as a trough to hold the lead and that worked well. I just had to use slightly less lead to balance the elevators.
Originally posted by Tim213 View PostI have the Model B wings and tried cardboard and plywood and both times it leaking onto the hangar floor. I tried several things to stop the leaks with no luck. I finally welded some thin steel plates as a trough to hold the lead and that worked well. I just had to use slightly less lead to balance the elevators.
I did very similar to Steve on my BH 4plc.with the tapered rib and it should work as well with the profiled rib.
On my Patrol I plan on doing the same as it allows you to remove the lead and paint the area.
The lead is held in on final assembly by bending the open edges into flanges and staking the hole edges used to balance.
You could also put a couple of flush rivets in as an extra if you wanted.
