This means that the cross connect cable will be SHORTER than that illustrated in your bench top setup.
So if I’m understanding correctly, the short arms of both bellcranks should be closer together, not further apart ?
I deliberately exaggerated the angles in the bench test in order to be able to measure the travel, but interesting to note that only a small amount of offset from normal will result in additional differential.
