Thoughts on engine selections......
    Once it’s moving and warm, it’s smooth. First 30 seconds or so when it’s really cold it’s shaky, and shutdown of course. But I would like to get a dynamic balance. But it did prompt the question if there’s a counterbalanced 360.
      Turns out this was an ignorant question on my part. I had the wrong idea about why counterweights are used. Here’s a good explanation. Apologies for the distraction!
      • #18
        Not an ignorant question at all. It prompted curiosity and led to shared knowledge!
        If your O-360 is that rough, on startup, I'd really take a hard look at the spark plugs and maybe the wires. When the plugs get fouled or gaps widen a bit, mis firing appears as roughness.
        • #19
          Annual found 6 out-of-spec plugs and mags a few degrees out. I’m sure I’ll have a “new plane” in a couple of weeks when the exhaust rebuild gets back!
          • #20
            Originally posted by Mark Moyle View Post
            Turns out the flywheel had a couple bolts and nuts from a previously undocumented static balance on a past prop.... found a cracked exhaust flange, and one additional crack and a missing tail pipe clamp at the muffler. The big find was the gookumpucky the A&P/AI used between the cylinder base flange and crank case....and quite a few under torqued cylinder base nuts.
            Mark were there any downstream effects on your engine from the goop you found on the cylinder flanges ? Where did you source your engine ?
            I've also found contamination on my cylinder flanges that has led to the failure of 3 cylinder studs HERE. I had purchased it (rebuilt) from a supplier recommended on this forum.
